What does completion code 8000020 mean in CANopen?
I'm running one of the example VI's for CANopen on NI-9881 module. What does completion code 8000020 mean?
(3,949 Views)
Hello Andy58,
Thanks for the post, what CANopen Example are you using with your NI 9881? Can you please to post a screen shot of the completion code.
Paul-B
(3,900 Views)
I was running CANopen_cRIO_Application.vi. I have not been able to duplicate the code but there is very little documentation in the manual or on this website for different message codes that are seen when running these vi's. I have also seen 8000040, 5040000, and 54A0A has also appeared. I have also seen these codes CANopen_cRIO_BatchSDO.vi and CANopen_cRIO_CANFrameRead.vi. I will be in your Austin facility next week for training and if possible maybe we can talk about the issues I am running into using this module.
(3,892 Views)
Here are the codes the NI master can decode using the API decode VI. Values are in Hex.
All codes not available might be defined with the device documentation that returns it.
DirkW
(3,865 Views)
