What does "resource not found" mean when loading VI?
I can't seem to open a .vi file. It says:
"Resource not found.
An error occurred loading VI 'dio_trigger_example.vi'.
LabVIEW load error code 8: Could not load VI resource."
I have LabVIEW 5.0 - do I need a newer version, or is the file not working? It is for digital IO using the DAQCard-6533. I was given this file by a NI technician....
Charles Brian Quinn
(4,298 Views)
They sent you a LabVIEW 6 VI.
(4,298 Views)
Resource not found problem
After more than 10 years later 🙂 I have the same problem. How to open such VI?
Igor Titov, ex-CLA
ex-Labicom.net, ex-CERN, etc.
(3,640 Views)
Why don't you attach the VI? Where did it come from? Is this the first time you tried to open it or is this an error you just started getting?
(3,628 Views)
I saved this VI (normally, without any notifications). And tried to open a few minutes later. After I failed to open it, I tried to do it on another computer - but with the same result.
It seems I can't attach this VI here because "The attachment file size is too large. The maximum file size is: 5,120,000 bytes", and mine is a bit more than 6 mb...
Igor Titov, ex-CLA
(3,623 Views)
That is huge for a VI. Sounds like it got corrupted. Restore from a backup.
(3,614 Views)
Yeah, of course I did, but still. Restoring from the backup means that a few hours of intensive coding was wasted... So, restoring from the backup is definitely a solution but it doesn't solve the problem itself - why LabVIEW (2011) corrupted VI and didn't save it properly?
Igor Titov, ex-CLA
(3,599 Views)
