What does the "Copy error code files" option do in the build spec properties
I agree with InfiniteNothing that this would be a nice feature for applications, without needing to build an installer.  Here's my solution: in your application setup, on the Destinations category, add a new location called errors.  Specify it as <yourAppDir>\user.lib\errors.  Go to Source File Settings, highlight MyErrors.txt (or whatever) and specify location as errors.  Build.  Instruct your customers to overwrite the entire <yourAppDir> with the new one you provide, which will now include a user.lib subdirectory with a sub-subdirectory called errors, with your error file.
Message 11 of 15
(1,527 Views)
You lost me at "instruct your customers". That's just not going to fly. It's just crazy that something on your block diagram isn't really in your code.
CLED (2016)
Message 12 of 15
(1,514 Views)
Fair enough.  My customers are all internal to my company, and engineers, so this works for me.  But I agree this isn't really good enough for prime time.
Message 13 of 15
(1,506 Views)
"It's just crazy that something on your block diagram isn't really in your code."
Referring to this I have the question, what is the function of the error rings on the block diagrams? Is it only for readability of the block diagrams?
Message 14 of 15
(1,438 Views)
Yes,  the error ring populates its selections from files ending in "_errors.txt" in specific folders.
Then extends error selection with definable custom codes with format specifier support that are saved elsewhere embedded in code.
_errors.txt can't use format specifies.  The text protocol and parsing routines were define ages ago...and are really .... let's give NI something of a break and describe it as "Arthritic "
NXG will improve that according to prophecy.
Message 15 of 15
(1,431 Views)
