What happened to the overwrite,always/ask/never pull down in the application builder. It was in 6.i. Any ideas on how to make the installer ask.
The builder in ver 6.0i had a pull down to address the over write issue for support files. My new ver 6.1 does not. Is there a work around, a solution, or a new ver on the way? Thanks
(2,463 Views)
6.1 now uses the Microsoft Windows Installer. Information on that can be found here. I have download the SDK but haven't started to play around with it yet. There is editor included that I believe will allow you to change the settings in the msi file. I think right now, the default is to overwrite files if what's on the installer is newer.
(2,463 Views)
