Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
chart with 6 signals (make each signal visible or not)
BK
Member
02-14-2003
05:24 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
i have a chart witch 6 signals. Now I want to make each signal visible or not (over a Button).
So it is possible to view only the interrested signals in case of special tests.
There is a menupoint in property-node->signals->visible?
But the visible property changes only the first signal in the chart. The rest of the signals are always visible.
Thanks for answering
BKE
0
Kudos
Message
1
of 3
(2,566 Views)
Reply
Re: chart with 6 signals (make each signal visible or not)
Alberto
Active Participant
02-14-2003
05:53 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
first you have to set which plot is active with the property Active Plot, then you can make it visible or not.
I attach a basic example.
Good luck,
Alberto
plot_on-off.vi 38 KB
1
Kudo
Message
2
of 3
(2,566 Views)
Reply
BK
Member
Author
02-14-2003
06:08 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks a lot Alberto...have a nice day
0
Kudos
Message
3
of 3
(2,566 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
