chart with 6 signals (make each signal visible or not)
i have a chart witch 6 signals. Now I want to make each signal visible or not (over a Button).
So it is possible to view only the interrested signals in case of special tests.
There is a menupoint in property-node->signals->visible?
But the visible property changes only the first signal in the chart. The rest of the signals are always visible.
Thanks for answering
BKE
(2,561 Views)
first you have to set which plot is active with the property Active Plot, then you can make it visible or not.
I attach a basic example.
Good luck,
Alberto
(2,561 Views)
Thanks a lot Alberto...have a nice day 😉
(2,561 Views)
