What happens if you do not poll a queue
I have a different classes that I integrate into different applications. Some of this classes write into a Queue data to be logged but in some applications this is not needed. Is there any penalty for writting into a queue and not polling out the data? What happens to the memory?
Hernan
(2,994 Views)
Hi Hernan,
i´m not really sure what you mean. You don´t need to poll a queue, you can use the "dequeue element" function with "-1" as timeout. It means that you wait til an event occurs. If you only write into a queue and don´t read from it, the memory usage will increase. See the shipped example, search for queue in the example finder.
Hope it helps.
Mike
(2,992 Views)
Thanks for the answer Mike. By polling I meant dequeing. The issue is that in some classes I have a queue that I use in some applications, but not in others. I could add a boolean to the class to determine if it should write to the queue, but if there is not penalty for queing without dequieng will make things easier.
(i.e. If I can set a limit of memory to use so when is reached that the queue will automatically delete older elements)
Hernan
(2,989 Views)
Hi Hernan,
you can set the size of the queue.
Mike
(2,986 Views)
Herman, Mike,
Setting the size of a queue does not do exactly what Herman asked. When the queue is full any attempt to enqueue another element will wait until the timeout and then return a timeout indication. To make a circular buffer from a finite sized queue, you need to add a wrapper VI which detects the enqueue timeout as an indication that the buffer is full, dequeues one element and discards it, then enqueues the new element.
Lynn
(2,963 Views)
Thanks for the info!
Hernan
(2,949 Views)
