What is Labview scripting?
Thanks a lot, dear friend jcarmody! This reply makes things understandable. And another thanks is due for the links. I am heading over there. I'll let you know of my experience.
Have a very pleasant day!
Message 11 of 23
(4,850 Views)
No one has mentioned it yet, so I must.  If you want to use scripting in LabVIEW 8.0 or above, you will need a license from National Instruments.  Contact you local sales representative.
Message 12 of 23
(4,826 Views)
Really? A separate license for using scripting? Does the normal LabVIEW license not work for the same purpose?
Message 13 of 23
(4,814 Views)
I've seen discussion of licensing re: distributing scripted appilcations (not sure that's possible; I've read that too), but wasn't aware that it's required in order to script your own IDE.  What is required?
Jim
Message 14 of 23
(4,807 Views)
Perhaps you should mention this to Michael Aivaliotis.
Message Edited by smercurio_fc on 12-16-2008 09:18 AM
Message 15 of 23
(4,795 Views)
The LabVIEW 8.x scripting license is not for sale.
I have thoughts about certain people who might have one, but they will never say in public (on a forum) that they will have a license.
But the things mentioned by Rolf about being unfished are very true if I must believe them.
Ton (No I don't have or need a license)
My LabVIEW Ideas
Message 16 of 23
(4,795 Views)
 C.Dot.
There is so much to learn in LabVIEW, and with programming in general, why do you want to learn scripting?  I tried it and it scarred the living crap out of me. Can you give one example of something you want to accomplish with scripting?
Richard
Message 17 of 23
(4,773 Views)
Broken Arrow wrote:
 C.Dot.
I wrote one Scripting based VI utility. It allowed me to point at a type-def'd cluster, and it automatically created an AE with methods (actions) that allowed to read/write any of the fields in the cluster. On machine at home it ran great. On my machine at work, it occaqtionally threw an error. Since I don't take chances with my customer's code, I decided to never use those AE's in any delivered application. The exercise what enlightening.
Just my 2 cents,
Ben
Message 18 of 23
(4,754 Views)
I'd love to learn scripting to do things like automatically align & distribute FP & BD objects (align & stack - I do that all the time) or clean up a wire with a keystroke, but I have so much to learn about general LabVIEW programming that I don't want to get sidetracked.  I use the SubVI Fixer, so I'm glad some folks script LabVIEW.
Jim
Message 19 of 23
(4,749 Views)
As you probably know, you can programmatically align FP stuff (with property nodes).
With scripting, you canprogrammatically align/move BD stuff, but it's hardly worth it for casual use. Good luck!
Richard
Message 20 of 23
(4,739 Views)
