What is objheap.cpp?
I cannot create a global for a cluster of enumerations
(4,187 Views)
I don't understand exactly. Could you give a little bit more information?
I could generate a global.vi with a cluster. The cluster includes 2 enum controls. I could write to the cluster global from a main vi.
objheap.cpp - this looks like you get a LabVIEW crash? Could you reproduce it? Could you attach your VI? and which version of LabVIEW are you using?
Regards
Roland
PS: The clusters with the enums need to match exactly.
(4,187 Views)
If you are getting a "fatal" LabVIEW crash that says something like this:
Failure: blahblah.cpp, line xyz in LabVIEW 6.0
Then you might want try checking out the following pages:
http://www.ni.com/support/failure/
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/01b186b5ceb1d07786256747000f4319?OpenDocument
http://www.medicollector.com
(4,187 Views)
I like this answer. I tried to reproduce the behavior, however I couldn't with LabVIEW 6.1. Maybe there is not enough info on how you get the crash?
Just remember, if you have a enum in a cluster and you create a global out of it, the enum needs to match exactly.
Roland
(4,187 Views)
