There are a no of Posts on this forum about this issue. If you run a search "Macros from Labview" you will get a bunch of posts. See if any of them fits.
As per your case... Here is a Link to a Post which may fit your need.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000E14E0000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=Run+Macros+from+LabView&USEARCHCONTEXT_QUESTION_S=0
Good Luck!!
Mache
Good Luck!
Mache
