What is property 104204298?
Does anyone know what property name is associated with property index 104204298?
It is a valid property for an Error Ring; the value is boolean, and is writeable, but changing it doesn't appear to have any effect.
(3,517 Views)
Where are you finding this property index? If you could post a screenshot showing where you are seeing this information, it may help clarify your request.
(3,480 Views)
In order to update my list of property indices (see http://forums.ni.com/t5/LabVIEW/Property-Indices-for-quot-Get-Property-quot-method/m-p/1526234#M5683...), I searched for valid indices for the new Error Ring object class.  Most of them were already known, but I have no info on 104204298.
(3,465 Views)
Oh ok,thanks for clarifying! That's actually a pretty cool list. Did you write some code to programmatically run through all the indices?
(3,440 Views)
As the list has evolved over the years, I've used a variety of utilities to flesh it out.  These days, when I find a new object (e.g. the Error Ring), I just run some brute force code that tries all the indicies (it takes a few days running in the bkgnd).  The more elegant approaches don't find everything; in fact for the Error Ring, using ordinary methods will find no properties at all.
(3,428 Views)
I’ve been looking through some documentation and haven’t found any mention of property name associated with that index. Is this information critical for any sort of application?
(3,398 Views)
I discovered that 104204298 is: "Visible Items:Subdiagram Visible" (which doesn't mean anything on an Error Ring).
However I've discovered several more property indices of unknown names that apply to Error Rings:
1594996736 Variant: Cluster
1594996739 Boolean
1594996740 Boolean
1594996741 Boolean
1594996742 String: (.html file name)
1594996745 Boolean
(3,348 Views)
