What is ring constant style?
Hi, I'm trying to programmatically create ring constant but I can't find its style...
Any idea what is the style for ring constant?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 1 of 10
(5,466 Views)
The help for the New VI Object Function is pretty straightforward about what it is.  I'm not sure I can explain it any better.
Bill
CLD
(Mid-Level minion.)
Message 2 of 10
(5,458 Views)
OH!  I think you are asking what you should select for "Ring Constant".  Sorry about that!  Sometimes I can be such a doofus.
I'm not sure what you should select.
SORRY!
Bill
CLD
(Mid-Level minion.)
Message 3 of 10
(5,446 Views)
I would say Text Ring (block diagram constant), as it seems that both the menu ring and the text ring become the same thing as a constant.
Bill
CLD
(Mid-Level minion.)
Message 4 of 10
(5,445 Views)
Accepted by bienieck
Please check below link for the list of styles:
https://lavag.org/topic/14519-new-vi-object-style-list/?do=findComment&comment=87007
-In the above post method also showed to get list of styles.
Spoiler
For Ring Constant it is 2008
 Just posting the same here: Source:https://lavag.org/topic/14519-new-vi-object-style-list/?do=findComment&comment=87020
Spoiler
uday
Message 5 of 10
(5,431 Views)
Funny because my style ring doesn't have item called Ring Constant.
Below you can see styles from LAVA and from my ring. Is it a bug? I'm using LabVIEW 2013.Styles.png
But thanks anyway. 2008 works 🙂
Michał Bieńkowski
CLA, CTA, CPI
Message 6 of 10
(5,370 Views)
I checked in LV2015 and i couldn't find it and it showed same as above.
-Anyway 2008 creates Ring constant 🙂
uday
Message 7 of 10
(5,344 Views)
OK, so NI guys, please do something about it 😄
Michał Bieńkowski
CLA, CTA, CPI
Message 8 of 10
(5,336 Views)
They already have done something about it.  As mentioned earlier you are looking for "Text Ring (block diagram constant)".  Check and you will see its value is 2008.
Message 9 of 10
(5,304 Views)
Ah Yes! I missed it it because it says "text" and I was looking for something like "named numeric" or such. Thx anyway.
Michał Bieńkowski
CLA, CTA, CPI
Message 10 of 10
(5,281 Views)
