Brian,
A related question on changing a portion of a large wavefrom on the
fly during continuous generation, perhaps on a standard E sreies card
or maybe a specific arb if that matters. If I have a 1 million
sample waveform generating at 1 MHz, can I change a portion of it by
simply writing the new data values to the waveform's buffer array at
the appropriate memory location ? I'd like to have that new portion
be used on the next waveform iteration cycle. Also, if it matters,
not have to worry about which half-cycle of the waveform is currently
being generated when I write the new portion to memory (perhaps a
question of whether double buffering is being used).
This actually would be done under Measurement Studio, but since it
per
haps is a question of NI-DAQ's capability and it relates to this
thread, I thought I'd ask here.
Steve
On Thu, 16 Oct 2003 09:03:25 -0500 (CDT), BrianA wrote:
>For some applications, we can can attain "glitchless" on the fly gain
>changes by restricting the change in gain to what the gain DAC can
>handle (thereby never switiching electronics in the output path).
