What is the diference between pane and panel?
Thanks.
(8,174 Views)
The panel is the UI part of the VI. It can be divided into several panes which are simply different parts of the same panel, which can have seperate scrollbars, etc.
___________________
Try to take over the world!
(8,166 Views)
If you open up the Example Finder (Help-->Find Examples), and switch to the "Search" tab, and enter "panels" you will find an example called "Toolbar using Splitter Bars" that shows a front panel with two panes.
(8,163 Views)
