What is the disadvantage of state machine?
@crossrulz wrote:
@REAL! wrote:
Isn't a state machine with a queue a QMH? Smiley Wink
Not quite.  There is a slight difference between a Queued State Machine and a Queued Message Handler.  They look alike, but the QSM handles its own queue to go through states while the QMH just accepts commands from other threads through the queue.
I would say that the QSM is an extension of the state machine, and QMH is an extension of the QSM.  Or, that's how I picture it in my mind's eye.
Bill
CLD
(Mid-Level minion.)
Message 11 of 19
(1,956 Views)
I would not state it quite that way.  A QSM is an extension of the Simple State Machine.  You can say this since they still act very much the same.  The QMH is in a different world.  Unlike the state machines that cycle through states in a somewhat deterministic way, a QMH just sits there and does something when it is told.  So you really can't call the QMH an extension of the state machine.  The QMH is actually an extension of the Producer/Consumer.
Nothing like arguing over semantics...
Message 12 of 19
(1,947 Views)
@Dennis_Knutson wrote:
...but NI will also lose points for such a question on the exam.
We've been doing some internal CLAD reviews...that question's days are numbered. 😉
Message 13 of 19
(1,940 Views)
And, semantically speaking, we're having a discussion, not an arguement.  😉
Maybe that's why I never could quite resolve why they didn't really act the same.  If I think about it, it does have a lot more in common with the producer/consumer.
Bill
CLD
(Mid-Level minion.)
Message 14 of 19
(1,908 Views)
If you really want to think about it, head over to this LAVA thread.
Message 15 of 19
(1,898 Views)
Sounds fun - and educational.  What could be better?  🙂
Thanks!
Bill
CLD
(Mid-Level minion.)
Message 16 of 19
(1,895 Views)
In the QMH design pattern there is a similar structure to SM, but it is not the same. SM in LabVIEW is a deterministic machine, however the structure present in QMH, called Message Handling Loop (MHL) is in essence a task handler, which is not necessarily deterministic. The fact that its diagrams are handled by a queue, which can receive a message from many different places (even externally) asynchronously, makes it lose the deterministic condition. It is therefore important to understand this difference correctly. It is possible to design a "queue-driven SM"’, but without losing sight of the above, such an SM is not strictly an SM.
But, if you decide to make a queue-driven SM, you must make sure that you have a tight control of the messages introduced in the queue so that the structure works in a deterministic way.
Message 17 of 19
(520 Views)
We were taught state machines in our Automata Theory course, but it was all theory and no practice. The existence of tools like lex yacc and bison were noted, though.
Message 18 of 19
(497 Views)
every program can be abstracted as a finite collection of states
however... do you always need to explicitly define every possible state?
- IMHO  this is  a proper usecase of statemachine (in the main.vi)
https://forums.ni.com/ni/attachments/ni/3039/11558/1/Read%20GIF%20File_LV71_V0101.zip
- this is an example of not using a state machine, which I think is the better solution in this particular case
https://github.com/dnattinger/read-xlsx-file/blob/main/source/NI%20Read%20XLSX%20File.vi
- the disadvantage of a state machine are, it can be slower  hard to read
Message 19 of 19
(436 Views)
