What is the maximun number of front panel objects in LabVIEW 7
I need to know what is the maximun number of indicators in a panel control, LabVIEW 7.0
(2,394 Views)
According to the post here the 555 limit in LabVIEW 6.1 is no longer in 7.0 but I don't know if there's a much higher limit or if you limited only by the amount of memory in the computer. How many do you have? By using clusters and arrays, you should be able to dramtically reduce the number. You might also want to think about moving seldom used indicators to subVIs that pop-up on demand.
(2,394 Views)
