What is the newest version of NI DAQ i can use with LABVIEW 5.0
Can Labview 5.0 be used with NI DAQ 6.8.9.
The Cards I am using are IMAQ PCI 1411, 6013 and PCI DIO 96. Should this combination work together ?
(2,911 Views)
I believe you can becuase there is a version of the NI-DAQ for LabVIEW driver for NI-DAQ 6.9.3 and LabVIEW 5.0.
J.R. Allen
(2,911 Views)
Also, I just realized something. You'll need more drivers to run your IMAQ hardware. So make sure you have that alos. NI-DAQ doesn't cover all IMAQ devices.
J.R. Allen
(2,911 Views)
Thanks for the relpy. I have got the DIO 96 and the 6013 operating in MAX, but it will not see the IMAQ 1411. I have also installed NI IMAQ v 2.2, still can't see the 1411. Is there new software that I will need to run for it to work ?
Rob
(2,911 Views)
The most recent version of hte NI IMAQ software is version 2.5.5. You may want to replace version 2.2 with that and see if it helps. This link will take you to the download page.
J.R. Allen
(2,911 Views)
Cheers, that has sorted the problem and now all my cards are operating in the MAX.
Rob
(2,911 Views)
Great! I'm glad you got it working. Best of luck with your application.
J.R. Allen
(2,911 Views)
