What is this icon?
Jyo263_0-1717738692904.pngHow to get one of these??
(1,058 Views)
One way: Create a queue of the right type, right-click the queue output, and "create constant".
(1,039 Views)
This is a Queue reference constant where the queue element type is the predefined type (a string). To create it, paste any queue function on the BD, right click on the queue or queue out terminal and then select Create > Constant from the context menu
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(1,038 Views)
Is the queue element type a string cluster??
(1,011 Views)
A queue element can be of any type. In this specific case is a String.
There is no such thing as a String Cluster. A Cluster is a container in which you can put a series of controls of several types. In a Cluster, you may even have a single String and nothing else (although usually it makes little sense). A Cluster with a single String control, however, i not the same as a String control alone.
I guess you should go through the LabVIEW tutorials as these are really basic information.
Paolo
(1,003 Views)
The queue element is a mixed cluster (pink) having elements differing in datatype. A purely numeric cluster would be brown.
(998 Views)
