What is your strategy to prevent repetition of the same code? (Please read caption below)
So this sounds like a general programming question, not specifically related to LabVIEW.  It would help us to know how much programming experience you have in general.
Bill
CLD
(Mid-Level minion.)
Message 11 of 22
(1,480 Views)
Mr. Altenbach, would you please create a code so I can better understand?
Message 12 of 22
(1,477 Views)
Not a lot of programming experience.  I have a lot to learn.
Message 13 of 22
(1,476 Views)
Not a bad thing.  We can mold you into a useless blob of Jell-o.  I mean a hardened veteran programmer.  Or at least not a raw recruit.
Bill
CLD
(Mid-Level minion.)
Message 14 of 22
(1,466 Views)
"a useless blob of jell-o" 🤣. I was like what? Thanks Bilko. I appreciate it. This is the main reason I am in here. I want to be like you guys.
Message 15 of 22
(1,460 Views)
My first thought is a Queued State Machine (I like JKI's).  Then the code is in one state that you call whenever/however you want.
Jim
Message 16 of 22
(1,446 Views)
I know exactly what you mean, but can you create a simple just so I can see how it works. I really want to learn these stuff.
Message 17 of 22
(1,440 Views)
Accepted by GRCK5000
See if this can give you some ideas....
Message 18 of 22
(1,422 Views)
Thank you very much, Mr. Altenbach for sharing the code. I spent quite some time trying to process it. I need an explanation on the part of the code shown below:
So when I use the probe where I have the red arrows. I was getting number from 65 to 70 and these numbers correspond to A to F, respectively.
My question is how do you know these conversions? Do you have a table that you can share maybe?
From decimal to hexadecimal conversion: 10 corresponds to A, B >> 11, C >> 12, and so on.
Can you please explain to me this conversion from the code?
Message 19 of 22
(1,408 Views)
See https://www.asciitable.com/
Another method, make a For loop in LabVIEW where N=256, change the i terminal to a U8 number and do the conversion.
Message 20 of 22
(1,403 Views)
