What's the best way to display color-coded telemetry?
I have an array of up to 64 name-value pairs -- one for each sensor channel (thermocouple, pressure transducer, etc.).  I would simply use an array of clusters with the name and value, but I also want to be able to flag when a particular value goes out of limit.  I want to change the background color of the value to yellow or red depending on the value.  As I understand it, I cannot change the properties of individual items in an array.  😞  So I'm forced to explicitly lay out 64 string and numeric indicators (even if I'm not using them all)!  Yuck.
Surely I'm not the first LabView user who wants to color-code a telemetry array display!  Is there a better way to do this?  I've looked at the multicolumn list box but that seems to be aimed at allowing the user to select something from a list -- not strictly display things.  Besides, I don't see a way to change the colors of an individual cell for the listbox either.
Please help!
Keith.
Message 1 of 12
(3,885 Views)
Add a colorbox to your cluster as a third element, make your value indicator transparent, and place them over the suitably sized color box. Now write the desired colors to the color box elements as needed.
Message 2 of 12
(3,884 Views)
OMG!  That's one of the ugliest hacks I've seen!  But it does work.  Of course, I can't change the font color to ensure high contrast when the background changes.
Why doesn't LabView have a cleaner way to do this?  Or at least a numeric widget that has built-in red/yellow limit processing?  I feel like I'm going to hell for sure if I use this color box hack ... 😉
Keith.
Message 3 of 12
(3,874 Views)
I agree it is ugly.
Since you want to exclusively use this as an indicator, you might want to display your data in a table indicator. Here you can set the color of individual cells at will.
Message 4 of 12
(3,869 Views)
Table sounds great, but I didn't mention that speed is also a concern.  When I use a table, my VI is way too slow compared to the collection of basic indicators.  Perhaps I'm not using the table efficiently?  Attached is a diagram of the update VI that sets the values and colors in the table.
Keith.
Message 5 of 12
(3,850 Views)
You should probably "defer panel updates" during the execution of the loop. It should make a big difference in performance.
(Do a search for "defer panel updates" here in the forum for details).
Message 6 of 12
(3,837 Views)
FYI, I wanted to be sure I'm using the fastest display approach, so I made a test VI to measure the 4 different approaches (attached).  Here are the results on my machine (10000 iterations):
Basic Indicators: 3.1 ms
Cluster Array: 0.002 ms
Table: 7.5 ms
Listbox:  9.4 ms
Something about the cluster array makes it 3 orders of magnitude faster!  What am I missing here?
Keith.
Message 7 of 12
(3,831 Views)
It is the only one that does not use property nodes.
Use the defer panel updates if you really have to use property nodes (as Christian said)
Message 8 of 12
(3,818 Views)
Also, there is no need to use a property node to read the "active cell" just to throw away all its data by overwriting both values a nanosecond later. (case table and listbox). Just use a diagram constant instead.
Message 9 of 12
(3,807 Views)
OK, I added defer panel updates and it did speed up the table and listbox significantly (down to around 3 ms) but still not as fast as the cluster array.  (BTW, replacing the active cell read with a constant had no effect.)  But here's what's weird: with the defer, the cluster array is incredibly slow -- around 7 ms!  Not sure what to make of this other than avoid property nodes at all costs -- even if it means using an ugly transparent indicator hack so I can change the BG color ...
Message 10 of 12
(3,769 Views)
