taking average and log of two readouts
Hi I currently have a labview program which operates a photon counter and counts photons on two channels and displays them in two separate graphs. I now need to be able to devide one data set by the other and take the log of the result, displaying this also graphically.
I am sure that this is possible and most probably quite simple, but I'm a labview novice to say the least so if anybody could advise me as to how I might go about this I'd be most greatful. I have posted my code below if that helps.
Cheers, Kelly
(2,466 Views)
The VI you posted has only a single graph so I don't know what two sets of data you mean. In any case, you can use the Divide and log functions on arrays - just like you can use them on scalars.
Message Edited by Dennis Knutson on 09-18-2008 09:57 AM
(2,438 Views)
