What would cause LabVIEW 8.2 to fail to see all methods of a .Net assembly?
Message 1 of 8
(3,621 Views)
We have a .Net assembly wrappering laboratory information management system functionality. However,
LV 8.2, 8.2.1 see only some of the methods for given objects. LV 8.5 sees all the methods. Same DLL under both tests.
What are the limitations on LV 8.2 regarding .Net method visibility? We can change our code to accommodate.
* Is there a limit on number of methods?
* Does LV 8.2 not handle strongly named assemblies quite the same way as LV 8.5?
* Are there (MS Visual Studio 2005 C#) annotations or method properties that would prevent a method from being visible to LV 8.2?
Would prefer to avoid shifting all instrument control to LabVIEW 8.5 if the cause can be identified.
Message 2 of 8
(3,616 Views)
I think there were limits in respect to static methods of .Net objects. Or maybe it was virtual methods?
Rolf Kalbermatter
Message Edited by rolfk on 11-29-2007 09:49 AM
Rolf Kalbermatter  My Blog
Message 3 of 8
(3,604 Views)
Howdy,
There were .net changes made in-between 8.2 and 8.5 but nothing like what you are describing. Could you post the DLL you are using for this so we can look into it?
Charlie M. CLD
Message 4 of 8
(3,578 Views)
Here:
http://iodp.tamu.edu/~fackler/.niforum/
lims-agent.zip
     Relevant DLL and supporting DLLs and config
methods-not-showing-screenshots.zip
     .rtf document showing symptom noted
Will remove after indication you have successfully rec'd.
Message 5 of 8
(3,562 Views)
Howdy,
Thanks for posting those DLLs. I saw the same behavior you described above. For now, you may want to look at these two forum posts: 1 and 2. They are cross referenced and discuss this behavior thoroughly. I will look into what has changed in 8.5 and post back when I find out more.
Charlie M. CLD
Message 6 of 8
(3,538 Views)
I can’t say for certain what change was made between 8.2.1 and 8.5 but I believe it was grouped in with a blanket of general improvements. We opened up the assemble in MS Visual Studio and saw all the same methods as viewed in LabVIEW 8.5.
Charlie M. CLD
Message 7 of 8
(3,521 Views)
Thank you Charlie.
Those were the kinds of pointers of I was looking for.
Making the move to LV85.
Message 8 of 8
(3,503 Views)
