Cryogenic SMS120C superconducting magnet power supply
Dear all,
has anyone here experience in accessing the aforementioned
"Cryogenic SMS120C superconducting magnet power supply"
over GPIB with LabView, and would be willing to give some hints / maybe
even share the code?
For details about the device, see the manufacturer website:
http://www.cryogenic.co.uk/products/electronics/power_supplies.asp
It seems to be pretty trivial to send commands to the power supply - "GPIB
Write" does the job and the device executes the commands (as can be seen
on its front panel). However I have not managed to get any status
information / command output back; when I do a subsequent "GPIB Read", I
always get only an empty line. ???
Thanks in advance for any hints;
best, Andreas
This message is transmitted using 100% recycled electrons.
Dr. Andreas K. Huettel tel. +31 15 27 88102 (univ.)
Molecular Electronics and Devices
Kavli Institute of Nanoscience Delft
Delft University of Technology A.K.Huettel@tudelft.nl
PO Box 5046, 2600 GA Delft mail@akhuettel.de
The Netherlands http://www.akhuettel.de/research/
Please use GNUPG or PGP for signed and encrypted email. My public key
can be found at http://www.akhuettel.de/pgp_key.php
(3,063 Views)
Hi Andreas,
Since you have been successful in writing to the device, it appears that your communication is working properly.  You may need to initiate a response or poll the device in order to read from it.  In order to read, the device needs to switch into talk mode, and the computer into write.  For specific information on this, as well as the exact communication protocol for your device, you will need to consult the user manual for the device.
You may also want to take a look at the following KnowledgeBase article, Why can I write to my GPIB device but cannot read back?
Lauren L.
Applications Engineering
(3,033 Views)
