When I change setting by LabVIEW to my device, Do I see change on monitor of device?
Vanny
)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(
Sweet, Beautiful and Young Female Physicist (SBYFP)
(I speak a not very good english, so If U are Italian LabVIEW expert speak in Italian, if U speak in Eglish... please speak easy;) )
My e-mail for personal contact: vanessaricciardi@live.it_NO_SPAM_PLEASE
(3,033 Views)
Could you describe what you mean about change setting by LabVIEW to your device. From your earlier post, do you mean communication settings, baud rate, parity, etc. ?  Setting to an instrument, by LabVIEW, should show up on the instrument, if successful.
Potresti descrivere cosa vuol dire un cambiamento impostazione di LabVIEW per il proprio dispositivo. Dal tuo post precedente, cosa vuoi dire le impostazioni di comunicazione, baud rate, parità, ecc? Impostazione di uno strumento con LabVIEW, dovrebbe comparire sullo strumento, in caso di successo.
Putnam
Certified LabVIEW Developer
LabVIEW Champion
(3,031 Views)
Accepted by vanny
This question should be directed at the manufacturer of the device. Based on your previous posts, I'm assuming that youre using GPIB or serial communication. If the device succesfully receives the command, then the manufacturer should be able to tell you if any of the indicators on the device update when the command is received. Based on my experience, however, the device indicators will most likely update upon successfully receiving a command.
(3,014 Views)
Change 😉
Vanny
(3,011 Views)
