When I´m editing a pallete - be it the controls palette or the function one - How can I edit a .mnu file, so that it shows the picture I want?
When one decide to edit controls or functions palletes, one of the options available is the insertion of a submenu and, when it´s done, the user is prompted to select which menu file - a file with a .mnu extension - he wants to use. All I want to know is how I can create a .mnu file so that it shows a picture I want - if instead of choosing a existent .mnu file I choose one that doesn´t exist, it will be created and a default picture will be shown. I went through the LabVIEW help without avail, so ...any help would be deeply appreciated !
(2,526 Views)
If you wish to change the default submenu Icon to yours, simply right-click on the submenu Icon and select "Edit Submenu Icon..."
Is that what you wanna do?
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,521 Views)
Thanks a lot Ian ! It seems I´ve forgot to try the simplest thing ...
(2,506 Views)
