When I maximize my FP at that time my gauge Control is not in shap..any idea..???
Hello friends,
I want to resize the FP, I am attaching screen shot with minimum and maximum FP look of other VI. in this Vi when I maximize the screen .Control remain same in shape ....
Message 11 of 15
(1,031 Views)
As I mentioned in my earlier post, did you check the VI Properties?
Your vi works as you want it to, if you uncheck the settings in Windiow Size of the VI Properties.
Regards
Freelance_LV
TestAutomation Consultant
Message 12 of 15
(1,021 Views)
Hello
Yes, I tried all possible option, still when it maximize.. Dial controls are unshaped ....
Message 13 of 15
(1,005 Views)
Accepted by Mr_Tejaskumar
Ok
I am not sure why this is so. However, i can suggest a work around for you. it works
This is not the best method to do it, but as i said, a work around.
you select the controls on the tab page (all of them above the waveform graph), as shown in the picture attached.
Group the controls and lock them as shown in picture. this should work
Regards
Freelance_LV
Message 14 of 15
(997 Views)
Thank you...
Message 15 of 15
(987 Views)
