When I try to write a 1D array to a spreadsheet file it doesn't work.
I only get a 0 in one column and none of the other data works...
Thanks for your help.
Bethany
(2,455 Views)
We need more information than what you have given.  Post the part of your code that you are having a problem with, or explain it in more detail.
- tbob
Inventor of the WORM Global
(2,453 Views)
