Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
When I try to write a 1D array to a spreadsheet file it doesn't work.
Bethany
Member
10-10-2005
01:56 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I only get a 0 in one column and none of the other data works...
Thanks for your help.
Bethany
0
Kudos
Message
1
of 2
(2,452 Views)
Reply
Re: When I try to write a 1D array to a spreadsheet file it doesn't work.
tbob
Trusted Enthusiast
10-10-2005
01:58 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
We need more information than what you have given. Post the part of your code that you are having a problem with, or explain it in more detail.
- tbob
Inventor of the
WORM Global
0
Kudos
Message
2
of 2
(2,450 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
