When I view .net assamblie in memory, I get error 1097
(3,143 Views)
Generally you get better responses if you provide some information. Like LabVIEW version/bitness, Os version/bitness, .NET Framework versions installed .. or even some example code if it's related.
Does this happen on any project or just a specific one?
Do you have the right version of the .NET Framework installed? I recommend having both 3.5 SP1 and the latest 4.x release.
(3,082 Views)
Labview 2018, .Net 4.8
(3,070 Views)
Of those five things, you've ticked off two. Can you also let us know your LabVIEW bitness, OS version and bitness.
(3,066 Views)
Labview2018 32bit,   Windows10 64bit
(3,053 Views)
I found this solution, but my dll properties have no content in the red cycle. There is blank.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8XnSAK&l=zh-CN
(3,046 Views)
When I open this vi, I get the error below. But after click ok, this vi can run correctly. Just every time I reopen this vi, I always get this error.
(3,040 Views)
