Problem with SystemLink/Skyline Tags in an NXG Web VI
I have an application where I need to pass data from LabVIEW to NXG.  To try this out, I am using the Multiple Tag Writer example project in LabVIEW, which runs a VI called Write Multiple Tags Client.  No issues running this VI in LabVIEW 2018.
In NXG 3.1, I have created a gvi that can read the tag.  (pictured in the attachment).  This works just fine.
I would like to make this a web VI.  I tried copying/recreating the code into a gviweb, but when I run it, I get an error:
"Javascript message: Failed to load http://localhost/nitag/v2/tags: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://localhost:52818' is therefore not allowed access.  The response had HTTP status code 402. in index.html at line 0"
Is there a reason why this kind of VI works as a gvi, but not gviweb?
Thanks.
(4,153 Views)
Accepted by topic author pulidotech
Since the WebVI is a web application running in a browser hosted by NXG, you probably need to enable CORS from the NI Web Server Configuration utility.
(4,134 Views)
That worked.  I'm glad the solution was simple.
(4,128 Views)
Follow up question.
I built the web application following this page:
http://www.ni.com/documentation/en/labview-web-module/latest/manual/building-a-web-application/
Then, I hosted it on the NI web server
http://www.ni.com/documentation/en/labview-web-module/latest/manual/hosting-ni-web-server/
I can see/run the application when I'm in a browser on the same computer.  I tried to access the web application on my phone (connected to the same network).  I can see the web VI, but I get error 363650.  It looks like it's related to CORS, but CORS is enabled for all, just like in your instructions.
(4,097 Views)
Hi, ,me too. I get the same error related to CORS. Is this problem is still occur? Did you somehow manage to overcome it?
(3,977 Views)
(3,956 Views)
