changing property nodes from a different vi
So, I am trying to monkey proof a GUI, I need to disable/turn visible off, some controls depending on the user selection and change it back to visible/enabled with others. Unfortunately, there are a lot of controls so my main prgroam is getting too big and hard to debug, so I decided to create some sub VIs to control each case and simplify the program. I read the help and apparently is possible to do this but for the life of me I don't see how. I am using the "Node Property" --> "Link to" selection to bind the control, but it only shows controls in the same VI panel, even if there are other VIs in the same project.
Can anyone help me or is this just not possible.
Thanks in advance
Message 1 of 12
(6,009 Views)
Accepted by topic author Elqui
Create a control reference from the main VI and pass it into the subVI and into the reference input on a property node.
Tim Elsey
Certified LabVIEW Architect
Message 2 of 12
(6,004 Views)
Spectacular. Thanks.
Message 3 of 12
(5,988 Views)
[Set Proud G-Daddy Mode = True]
One of my rookies wrote some re-use code that leverages off of an XControl to allow access to a control ref of any VI in an app from anywhere. As you can tell by me posting this message, I was pleased with his final solution. (Yikes, I have created a monster!) No I can't post his code but in-case anyone was wondering if it could be done.... the answer is Yes!
[Set Proud G-Daddy Mode = False]
Ben
Message 4 of 12
(5,969 Views)
How do I use control, when I'm calling a SubVI dynamically? Since I'm using Run-Time Menu here, I had no other option to program..
Pradeep
Message 5 of 12
(5,688 Views)
Hi Pradeep,
Use "Control Value Set" method to set/get value from controls/Indicators
Pls see the attached image that setting value to the boolean  control named "Bool1"
Message 6 of 12
(5,673 Views)
Hi G K,
Thanks again,
       My problem here is not to set the value of the boolean control, but to enable it inside the SubVI, whenever I'm closing panel. I've used panel close event here.
       As you can see in my screenshot, I'm disabling the Trend button. I want this to be enabled once I close the called SubVI.
       Ill attach my complete code for your reference.
Pradeep
Message 7 of 12
(5,664 Views)
Hi pradeep,
First of all you should have started new thread.
Now for your question. Try with following vi.
Let me know.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 8 of 12
(5,656 Views)
Guarav K. Do you think there is a way to implement the same idea as yours for setting the browse start path property of a path control located in a subvi using code written strictly in the man vi?
[BADGE NAME]
Message 9 of 12
(4,885 Views)
Try this
mcduff
Message 10 of 12
(4,881 Views)
