Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
When I want to install the SQL Toolkit V3.0 (Labview 5.11, Win2000)the installation stops before the "Preparing Installation shield"-Window shows up.
amuehlen
Member
06-01-2001
03:44 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Error:
Anwendungspopup: Win16-Teilsystem: Die NTVDM-CPU hat einen ungültigen Befehl entdeckt.
CS:023e IP:00ca OP:c4 fe cd 05 c4 Klicken Sie auf "Schließen", um die Anwendung zu beenden.
(The NTVDM-CPU detected an invalid code)
0
Kudos
Message
1
of 2
(2,509 Views)
Reply
Re: When I want to install the SQL Toolkit V3.0 (Labview 5.11, Win2000)the installation stops before the "Preparing Installation shield"-Window shows up.
JellyBeans
Active Participant
06-01-2001
04:24 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Do you have "OBDC DataSource 32bit" in Control Panel>>Administrative Tools?????
Can you also try on someother computer that has same software installed? Consider the possibility of upgrading that toolkit since it is VERY old one.
A Rafiq
0
Kudos
Message
2
of 2
(2,509 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
