Win2000pro terminates application
My LabVIEW5x application (exe or not) is closed by win2000pro because it creates several temp files in the temp directory. Windows suggests that these temp files are "NOT A VALID WINDOWS IMAGE". The temp files are created by CINS or dlls, ie. SQL toolkit, old style serial driver, etc. Any ideas? This is a cutting from one of the temp files, is this normal? They are cleaned-up when the app closes (if it doesn't crash).
Temp file cutting:
LVRTTable Fatal Error LABVIEW.LIB was not called from a LabVIEW process. �S JT âS îS T ÎS
T T ÀS T 0T yInitializeCriti
calSection L DeleteCriticalSection �LeaveCriticalSection îSetCommState ¨ GetCommState § GetCommProperties ;SetupComm  CloseHandle C CreateThread . CreateEventA ïSetCommTimeouts © GetCommTimeouts 1 CreateFileA X EnterCriticalSection ÂPurgeComm ?Sleep SetEvent jWaitForSingleObject 3SetThreadPriority j EscapeCommFunction  ClearCommBreak ëSetCommBreak  ClearCommError
GetOverlappedResult ô GetLastError {WriteFile áResetEvent ÖReadFile GetProcAddress þ GetModuleHandleA KERNEL32.dll r __p__pctype d __p___mb_cur_max _isctype Dexit MSVCRT.dll Yfree _initterm �malloc � _adjust_fdiv �MessageBoxA USER32.dll Q DisableThreadLibraryCalls
 è 000!0%0+0/05090?0D0]0i0�0²0¾0Ë0Ö0ù0 141C1a1�1³1î1*2O2k2q2¨2å2í23\3�3�3¬3»3Z4n4t44�4Â4ú4 55!5A5W5a5v5|5�5 5¨
Certified LabVIEW Architect
(3,222 Views)
Are all of your Dlls and CINs W2k compatible ("old style serial driver")?
Do you have any other processes running in the background which may be
influencing these files?
Shane
martins bit schrieb in Nachricht
<506500000008000000A01F0000-986697009000@quiq.com>...
Temp file cutting:
process.
�S JT âS îS T ÎS
T T ÀS T 0T yInitializeCriticalSection L
 è
55!5A5W5a5v5|5�5 5¨
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,222 Views)
All the CINs & DLLs should be Win2Kpro compatible i.e. SQL toolkit. By the "old style serial driver" I mean the non-VISA type shipped with LV. There may be something running in the background that I'm not aware of, started by the network log-on, I'll check.
Thanks Shane
(3,222 Views)
Probably best if your app does NOT create or keep files in the Windows
temp folder. They are vulnerable to automatic clean-up and other
operations!
Best, Mark
(3,222 Views)
