When the integral function is placed inside a wait until next ms multiple is it reset at the beginning of each loop?
When the integral function x(t) is placed inside a wait until next ms multiple while loop is the Integrator reset to zero every time the loop executes?
(2,731 Views)
the function works on a discrete amount of data. Hence every call to it replaces the values used first time around.
I've attached an example in LabVIEW 7.0 that uses a pulse generation vi to allow the manipulation of the array sent into the integral object, and then it's easy to calculate what the integral of the data would be.
Hope that helps
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(2,731 Views)
