When two acquisition cards run in parallel, one acquisition card always runs at the highest sampling rate and cannot be changed
Accepted by topic author JHUN-KULI
Hi Jhun,
@JHUN-KULI wrote:
What I mean by changing the sampling rate here is that when the program is not running, the input value of the sampling rate of THE RT terminal is changed, and then the VI of RT is run. At this time, the RT terminal will load the parameter data into FPGA before data collection. When I stop running rt. vi, re-enter a new sampling rate and run rt. vi again, at this time, 9232 still collects data at the maximum sampling rate.
You just "Run" the FPGA VI in your RT VI. Typically when the FPGA VI already is running it will not get restarted by calling the "Run" method again!
Solutions:
  • abort and run the FPGA VI correctly in the RT VI
  • when parameters should be changed in the FPGA VI you should place the code to handle those changes inside the main loop(s) of the FPGA code…
Message 11 of 11
(378 Views)
