Where can I download the switch driver for labview 3.0
Our lab has been using labview 3.0 in a power macintosh. Now we need the
following drivers, I checked Ni website and only got those drivers for
labview
5.0 and 6.0, no 3.0.
I will apprieciate if you could tell us how to get it.
Manufacturer(s) Keithley
Description Switch System
Model(s) 7001
Interface(s) GPIB
Instrument Type Switch System
Original Release Date 01/01/94
Manufacturer(s) Lake Shore
Cryotronics
Description Auto-Tuning Temperature Controller
Model(s) 330
Interface(s) GPIB
Instrument Type Auto-Tuning Temperature Controller
(3,123 Views)
I tried to answer your email but got a failed email address. You might want to check the given email address in your ni profile for correctness.
I was able to locate the LabVIEW 3.1 versions of these drivers. You may want to consider upgrading as a great deal has changed since LV 3.0 and it is no longer supported.
Hope this helps out!
Best Regards,
Aaron K.
Application Engineer
(3,123 Views)
Great, thank you.
(3,123 Views)
Thank you, Aaronk
There is new problem now. Our macintosh system crashed and was just repired. Now labview can run but our DAQ card NBGRIB/TNT can't get any signal at all! I tried to run Ni-daq command and inside I can find DAQ card. When I double clicked it, it is said" No I/O connector diagram is availabe for NBGRIB/TNT".
(3,123 Views)
It is hard to say what this could be. I would suggest uninstall/reinstall the driver. If that fails, consider generating a new discussion thread over in the DAQ area.
Hope this helps!
Aaron K.
(3,123 Views)
