Where can I find VST drivers for LabVIEW 2024?
@cgiustini wrote:
Yes, exactly I want to change the FPGA. That is still possible on the latest VST hardware/software right?  Or do you know if that capability was removed?
I don't have hardware just yet so I cannot test whether or not RFSA and RFSG software front panels or examples work. But I do know that at least the soft front panels are there, which indicates that RFSA and RFSG software has been correctly installed.
Yes,  you can still use a custom bitfile.  I believe you need NI RIO drivers.  NI RIO will be encluded with the hardware.
Message 11 of 15
(736 Views)
I think RIO driver is the term used when LV FPGA first came out when there were less product lines.  As above, the term is still used.  These days I recommend being more product line specific (e.g., FlexRIO, R Series, cRIO).
To load a custom bitfile into any of the 1st and 2nd gen VSTs, see https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000g2pKSAQ&l=en-US.  You just need the RFSA and RFSG drivers.
VST3 (5842) does not currently show anything in the documents I checked.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 12 of 15
(709 Views)
@JÞB wrote:
I would be looking at RFmx. RFmx (Radio Frequency Measurement eXperience) builds on top of RGSA / RFSG similar to how DAQmx replaced Traditional DAQ. I would certainly have expected that pre-RFmx IDL support would be obsoleted by now.
Check licensing for this.  RFmx is not free, see https://www.ni.com/en/shop/wireless-design-test/application-software-for-wireless-design-test-catego...
RFmx will be a replacement to RFSG and RFSA when there is a part that is free (as part of hardware purchase).
ALE Consultants
Message 13 of 15
(707 Views)
I recommend getting an official answer directly from NI.
ALE Consultants
Message 14 of 15
(704 Views)
Hi again
Found the IDL download location for the now very old versions, and NI's statement about that :
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000g2pUSAQ&l=da-DK
Quote : "For the majority of use cases, NI recommends using the pre-compiled reference FPGA image provided with NI-RFSA, NI-RFSG, and NI-RFmx."
There are only downloads for these LV 2013 to 2015 compatible IDL versions :
Here :
https://www.ni.com/en/support/downloads/drivers/download.labview-instrument-design-libraries-for-vec...
Regards
Message 15 of 15
(687 Views)
