Where can I find detailed Information about the function of property nodes
for example:
The "Active X Scale" - Property of a XY Graph.
What can I do with it?
thank you
Thomas
(2,858 Views)
Hi thomas
Labview help provides infomation about property nodes.
1.-create the property node
2.-select the property you want info about
3.-Open the window "show contex help"
4.-Set the cursor on the property and you will see an explanation about it in the help window, with option to acces more information, if available.
Hope this helps.
Alipio.
"Qod natura non dat, Salmantica non praestat"
(2,858 Views)
Hi Alipio,
thank you for answering.
I found the help about the "Active X Scale" - Property.
But there is not said, what "Active X Scale" means. What can I do with it?
What happens, if I write 2356 to this property. What is it made for?
I hope you understand, what I mean
Thank you
Thomas
(2,858 Views)
Hello Thomas.
I see what you mean. I dont know if National supplies that informatios.
I used "active X scale" in an application where 4 diferent x scales and plots are in use. This property is used to select to what scale you are going to apply the scale properties. It is similar to "Active cursor" to select cursor, "active plot" and "active Y scale".
Hope it helps. Should you need further info, I guess National can supply it.
Alipio
(2,858 Views)
Hi Alipio,
I thought, there must be a place, where we can find informations about for example the Active X Scale - Property.
Or all the other things which are not dokumented in the handbook or in the help-files.
Seems not.
Thank you for helping
Thomas
(2,858 Views)
