property node of a hidden XY Chart problem
Hello All
I have two XY charts, on different TAB pages. Every one has been Zoomed In. After clicking on some button, they should come to the autofit mode, which is accomplished by a reference node (XScale.ScaleFit).
The problem is that only the graph which is visible accepts the commands. The one which is hidden in the other TAB page does not accept property node (unless you show it).
I tried to select "ActPlot" and "ActXScl", but it did not help.
What shell I do more to force hidden plot to autofit the data it already has?
Thanks in advance
Pawel
(2,754 Views)
> already has?
The deal is that the graphs and charts try not to be CPU hogs when
hidden. That means that they don't autoscale, they don't draw, they
don't do much of anything. This is true for the autoscale always as
well as the autoscale once. Perhaps it should be changed of the once
case, but at the moment it looks the same to the graph. Anyway, one
option is to figure out what you want the scales set to and just set the
scale range values. Sometimes this is trivial, like on X scales. If it
isn't trivial, and you are already using a state machine, have the
button store its press in some state info so that when a hidden chart is
being shown, it does the autoscale then.
This means that the visible
charts will do the autoscales, and if the user never looks at the other
charts, no work was done.
If you would like to see the autoscale once changed, consider filing a
bug report.
Greg McKaskle
(2,754 Views)
Thank you, I think I will select the scale manually.
Pawel
(2,754 Views)
