Where can I find/load/include agesa_32.dll?
When I used Labview 8.5.1 to start an application written in Labview 8.5, I am getting an error because the application could not find "agesa_32.dll". Previously I had added agesa.lib under Labview 8.5\instr.lib\  and it did not complain.
I was wondering if you could direct me to a location where I can find the shared file agesa_32.dll. I tried searching for the dll in the "Instrument Driver Network" for Agilent analyzers but could not find it.
A Novice
(3,113 Views)
Accepted by topic author A Novice
It's part of the driver. It gets installed into the \vxipnp\WinNT\Bin folder I believe. If the only thing that you was copy the llb from an old pc to a new one, that is incorrect. You need to run the install program for the driver and also install the IVI Compliance Package.
(3,102 Views)
Thank you very much Dennis,
I installed agesa_LV82 for Labview 8.2 and I can see the dll file now in VXIPNP\WinNT\Bin folder.
Cheers,
A Novice
(3,092 Views)
