Where can I find the multiple node block
I am looking for the symbol that takes the negative and positive peakc and outputs one signal to measurement file:
Figure 4.
http://zone.ni.com/devzone/cda/tut/p/id/4644#toc1
(2,708 Views)
Accepted by Oreos
If you're referring to the small yellow block between the big two blue blocks on the right-hand side of Figure 4 of that document, then that's the Merge Signals function. It should be in the Express -> Signal Manipulation palette.
(2,695 Views)
