03-22-2007 10:16 AM
03-23-2007 05:15 PM
Iskander,
This function, IMAQ Remote Compression.vi is not in the palettes, but if you use context help (ctrl+H) and hover your mouse over the vi, you will see the data on it. In the context help window, if you press the small left most button in the corner, it will display the path. On my computer the path is: C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\vision\IMAQRTCompatibility.llb Let me know if you have anymore questions!
-Allison S.
Applications Engineering
03-26-2007 03:03 AM
03-27-2007 10:22 AM
Iskander,
I think I know what may be happening. In order to see that library you need to have both LabVIEW RealTime and IMAQ installed. Not only that, but when IMAQ is installed, the option for RT support needs to be included. What I would recommend is to make sure that this is the case on your computer.
Go to Start >> Settings >> Control Panel >> Add/Remove Programs, select "Change" for National Instruments Software. In this list find your IMAQ driver and click "Modify." Have your IMAQ driver CD available for when it asks for it. Once the CD is put in, a window with all of the install options will open -- make sure it's set to install support for Real Time and run the modification. Let me know if that helps make this library available. Thank you!
-Allison S.
03-27-2007 04:11 PM
03-28-2007 02:24 PM
Iskander,
So you opened the installer and added support, or was support for RT already included? Was the option for RT available in the list under IMAQ? When you asked it to run after selecting the option did it show you the list of options and then install them, or did it give you an error? At what point did it fail? If it installed without error, did you restart your computer afterwards?
The more information I can find out about what happened with the install the better. If you got an error or anything, a screenshot would be very helpful. Thank you!
-Allison S.
Application Engineering
04-01-2007 11:40 AM
Hello Allison S.
I havn't the RT
How can I buy the RT
Best regards
Iskander
04-03-2007 01:59 PM
04-12-2007 09:53 AM
04-13-2007 03:35 PM
