Where can I get driver for Tektronix2440 Oscilloscope for LabView 5.0 version?
Our Lab have LabView 5.0 version and VI for Tektronix2440 Scope for LabView 3.1 version. For our switching experiments we need of a newer driver for Tek2440 to work with LV 5.0.
The main problem is our A/D converter hasn't a memory and so we can not get the data fast enough (data acquisition is not greater than 26 scans/sec. 1000 scans/sec and greater are required). We are solving this problem by writing the data to oscilloscope and then reading them to LV.
Thank you.
Message 1 of 8
(3,061 Views)
Give this a try.
Message 2 of 8
(3,061 Views)
Thank you Dennis, but I need tek2440.vi programme for Tek2440, not library. My programme doesn't work. The problem is in the read-write sections.
Message 3 of 8
(3,061 Views)
I don't understand what you want. The LLB I converted has Tek 2440.vi inside of it for programming the scope. It's the the only driver I know of for this thing. Are you having problems getting this driver to work or some other problem?
Message 4 of 8
(3,061 Views)
Sorry Dennis, I'm new user of LabView, sure you are right. But I cannot open this library from MacOS. Is the library you sent me for PC?
Message 5 of 8
(3,061 Views)
It was originally but LabVIEW for MAC should be able to open it. Start LabVIEW, chose open, and select the .llb and you should be able to see the VIs inside. I don't think there's anything you can do from the MAC OS to view the contents of a LabVIEW library. I'm reattaching the file in case it got mangled somehow. I wish I had a MAC to verify the contents but I don't.
Message 6 of 8
(3,061 Views)
The problem have cleared up now. Tek2440 VIs you sent me is all right. But there is still main problem: I can not write data from oscilloscope to computer. There is "hand maid" program (written not by NI) in my computer that used to do it, but this program does not work now. So NI's VIs work well. Thank you very much for your help.
Message 7 of 8
(3,061 Views)
The problem have cleared up now. Tek2440 VIs you sent me is all right. But there is still main problem: I can not write data from oscilloscope to computer. There is "hand made" program (written not by NI) in my computer that used to do it, but this program does not work now. So NI's VIs work well. Thank you very much for your help.
Message 8 of 8
(3,061 Views)
