Where can i find examples or illustrated "how does it work?" in automotive electronics topic?
I look for samples "how works automotive equipment" for LabView programme. Maybe somebody can help me find this software samples. I interested in brake system, control engine, gearbox, suspension, CAN or MOST bus, ignition system, multimedia in car et. PLEASE HELP ME!
Tomasz Widerski
tomwider@ck-sg.p.lodz.pl
(2,913 Views)
Try digging through NI's web site. There is a great search engine found at www.ni.com >> support >> advanced search (it is at the bottom--click on the words). This launches the best way to search NI's web pages because you can limit your search to materials of interest. Start by entering labview automotive in the all the words field and search all the resources. In the future, you can search just the discussion forum, example programs, etc. Place a bookmark here--you will want to come back.
Jeremy Braden
(2,913 Views)
Tomasz,
There are some resources on the ni.com site you might find useful. One is www.ni.com/automotive, you can find quite a few items addressing the topics you indicated.
The other industry solution areas might also be useful: www.ni.com/solution
I used the "Solution Finder" (http://www.ni.com/solutions/solution_finder.htm) on this page and entered the different key words you mentioned "brake", "multimedia", "CAN" and found quite a few resources that listed the equipment as well as some software sample code to use with the equipment.
Best Regards,
Kamran Shah - NI
An
(2,913 Views)
Checkout http://www.automotivetestsolutions.com. It is not a PC/LabVIEW
solution but may be very useful for what you are looking for. LabVIEW was
used to help develop this product and is used to test it out after
manufacturing as well.
Best Regards,
Neal Pederson, President, VI Control Systems
1923 Mendius Lane, Los Alamos, NM 87544
TEL: (505) 662-1461, FAX: (866) 422-2931
np@vicontrols.com, www.vicontrols.com
"6734116" wrote in message
news:50650000000800000045490000-1021771306000@exchange.ni.com...
> Tomasz Widerski
(2,913 Views)
