Where do I get the Excel VI's from?
   I am trying to convert Labview code from 7.1 to 8.25 and I am missing the following sub-vi's, they are:
  1. Set Cell Value.vi
  2. Open Excel and Make Visible.vi
  3. Open New WorkSheet.vi
  4. Open Specific WorkBook.vi
 Where do these vi's come from for 8.25?
 Kaspar
Kaspar
(3,507 Views)
Are you using 8.2 or 8.5?
I haven't heard of any of these VI's before.  I suspect that they are ones someone else wrote and aren't from NI.
(3,501 Views)
Whether you are converting to 8.2 or 8.5 (there is no 8.25) they are in the same place as 7.1 - Examples\Comm\ExcelExamples.llb
(3,501 Views)
  Sorry for the confusion, I am trying to convert to Labview 8.2.  Ok, so I will look in the same relative location in Labview 8.2. The vi's that I am missing in inside a library (as opposed to being discrete file). So how do I get to the vi, when I have a block diagram with question marks for the VI icons because they are considered missing?
Kaspar
Kaspar
(3,492 Views)
When you are prompted to locate the VIs, just browse to the location I mentioned, double click the llb, and select the VI. You should only have to do this for the first subVI.
(3,487 Views)
  Thanks for the response. I am trying to change some code that someone else wrote from one version to another and it is nice to have help solving problems!
  Thanks again
Smiley Happy
Kaspar
(3,471 Views)
