Where/how do I get a "Run-Time Engine"?
I need to check out operation of my Labview program on another computer in another lab.  I developed it using Labview 7.0, and now need the "Run-Time Engine" to load onto this computer.
(2,656 Views)
You can download it from HERE ! 🙂
Select LabVIEW...LabVIEW runtime...7.0 ... etc.
(Of course this requires that you built your program into an executable. Do you have LabVIEW professional or the application builder add-on?)
Message Edited by altenbach on 10-27-2005 11:10 AM
(2,647 Views)
Since the RTE only makes sense if you built an executable, you can create an installer and choose to include the run-time with that, you cna also get it from your LabVIEW CD in the \Components\lvruntimeeng folder, or download it from here.
(2,643 Views)
