Where / how does LabVIEW store user-defined color pallettes?
Hi everyone,
in order to introduce CI defined colors into our VIs, I entered all needed colors in LabVIEWs color dialog box by hand using the RGB codes just to find out, they had disappeared after the next start of LabVIEW. Is there a way (some kind of ini file) to make them available permanently?
Haven't found anything yet on the forum or in the help system.
Cheers
Oli
(3,456 Views)
Hi Oli,
colors choosen in the color dialog box are stored in LabVIEW.ini.
When you need color values permanently you should store them either in your VI (by creating constants or setting default values of controls) or in your own files…
(3,452 Views)
Accepted by Oli_Wachno
Yes there is.
Tools>>Options
the ini entry is in this format
colorUserItem="3D Object=BCBCBC;Control Background=FAFAFA;Indicator Background=D2D2D2;3D Active Object=969696;Text=000000;LED On=64FF00;LED Off=1E4B00;Thermometer Fill=FF0000;Slide Fill=0041DC;Slide Housing=6D6D83;Tank Fill=0041DC;Tank Housing=A9B3CB;Classic Object=B3B3B3;Classic Slide Thumb=3399FF;Refnum Wire=007F7F;Template Comment=91FBFE;Warn=FF7F00;DAQ=893900"
WARNING: Most of these colors apply to new vis, no change is made to existing vis however, "Coersions dots" apply to new or existing vis. Blink FG and Blink BG applies only to new vis.
Changing Some of those can be a royal pain.  For instance you would not want to remove "Control Background" and replace it with "Passed"
(3,442 Views)
Perfect, thanks a lot! Didn't dive deep into the option dialog. But I knew, there must be a possibility Smiley Happy
Have a good weekend!
(3,403 Views)
Be sure and thank users by giving kudos, and marking posts as the answer to the topic.
(3,383 Views)
