Where is DAQmx Is Task Done.vi?
I have a new Windows 7 SP1 x64 installation with LabView 10 installed. It prompted for one (32-bit) patch and I installed it. Tried to launch some third-party vi and it's gives me a prompt asking where is the DAQmx Is Task Done.vi?
From what I can tell, this vi should be builtin, but I don't see it anywhere in LabView directory (or at least Window search doesn't). What could be going on?
(3,857 Views)
Have you installed the DAQ driver ?
(3,855 Views)
Yes, I had already installed 9.3 of DAQmx before I installed Labview. Do these versions not mix? The card (6251) shows up OK in device manager.
(3,848 Views)
Accepted by mauricev
I would try to repair the DAQ installation.
The order of installation of LabVIEW is normally first LabVIEW and then the drivers.
The driver vi's is probably not being installed, as LabVIEW was not installed before.
(3,844 Views)
Do you see it in the palette?
Meas IO > DAQmx > DAQmx Advanced Task Options > DAQmx Is Task Done.vi.
EDIT: Oop, I missed that "before Labview" part.  dkfire is right, you must install toolkits AFTER LabVIEW or they don't know where to install their drivers.
(3,844 Views)
