This widget could not be displayed.
Where is the PID (FPGA) Express VI?
I have LabVIEW 2013 RT and LabVIEW FPGA installed on my Windows 7 machine.  Which palette is the PID (FPGA) Express VI on?  I have looked on both the RT and the FPGA palettes.  I have looked for the example C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\control\PID\fpga llb\CompactRIO.  The example is not on my machine.
(3,665 Views)
At least in LabVIEW 2012, it's under FPGA Math & Analysis -> Control. Sorry, can't check under 2013 right now.
(3,663 Views)
I don't have an FPGA Math & Analysis -> Control on 2012 or 2013.  Maybe I failed to load everything I need.  Here is my palette.
(3,640 Views)
Untitled.gifHere is the palette.
(3,631 Views)
Please see the Note in the PID (FPGA) Express VI help:
"This express VI is available only if you install both the LabVIEW PID and and Fuzzy Logic Toolkit and the LabVIEW FPGA Module."
You'll need to install both toolkits in order to get the PID (FPGA) Express VI.
Edit: Your image of the palette didn't show up for me the first time, but now it looks like you are looking at the palette under the RT target and not the FPGA target. If you open a VI under the FPGA target, you should see the FPGA Math & Analysis palette.
Donovan
(3,629 Views)
It's not under the FPGA Interface palette. To see it, you must be working in the block diagram for a VI that is loaded under an FPGA target. The FPGA Math & Analysis palette is directly on the programming palette, and there is a Control palette under it.
Have you tried searching the palettes for PID, using the search button in the upper right of the palette?
(3,625 Views)
Thanks.  It does show on a vi under the FPGA Target.
(3,620 Views)
