Where should i put my input signals?
hi ,
Here is the very first part of my fpga program (i think where i should put my input signal ).
Our input will be the voltage(V)  . But then i  m not so sure about where i should put my input into the fpga program .
Could you please kindly advise me a way to put my input signal ?  Thank you . I am looking forward to your kindly reply .
With regards , roxy
so sorry for duplicating messages Smiley Indifferent ..
Message Edited by SarahM on 06-27-2008 09:26 AM
Message 1 of 19
(4,090 Views)
Not only did you post all of those partial questions, you embedded something in your post that asks to log into 'stud mail'. Delete it. Click on the Options button and select Edit.
Message 2 of 19
(4,089 Views)
sorry the picture is over here
Message 3 of 19
(4,067 Views)
roxylat
Please as Dennis asked, Edit your first post and delete the object that is causing a prompt for a mail login!
SteveA
CLD
FPGA/RT/PDA/TP/DSC
Message 4 of 19
(4,062 Views)
But how its possibe to edit the first post after it was half an hour gone.....
Message 5 of 19
(4,059 Views)
Hi Everyone,
It's not possible.  However, if you go to the Options menu on the right side of the window and select Report to Moderator you can ask a moderator to edit the post for you in situations such as this.  I have gone ahead and edited the post above.
Happy Friday!
Sarah
Message 6 of 19
(3,990 Views)
Roxy,
The best way to start working with the FPGA to input signals would be to use one of our shipping examples. You can find them in LabVIEW by going to Help >> Find Examples. Then in the search tab enter the name of the module (if you are using cRIO) or your PCI FPGA device (PCI-78xx) that you using to input your signal. Alot of our devices have these getting started examples and they introduce you to basic IO.
Let me know if this points you in the right direction. What NI FPGA device are you using?
Cheers,
Jonah
Jonah Paul
Marketing Manager, NI Software
Message 7 of 19
(3,960 Views)
thank u very much for ur reply.yah, we are using cRIO 9012.
Message 8 of 19
(3,950 Views)
i  m using 9012 for the controller , 9233 for the module (processor) and 9101 for chassis ..
Message 9 of 19
(3,922 Views)
hi jpaul ,
i have been gone through ur suggestion. From tht what i understand is these 4 ports should be my inputs ....is it correct? if i m wrong , please suggest me for my inputs. By the way , the input signals would be Volt(V) ... thank you . I m looking forward to ur reply ..
with regards ,
roxy
Message 10 of 19
(3,915 Views)
